Brief Description: Right Stabilator - Stabilator Preparation
"I measured the requred lengths of C channel pieces for the front and rea sparrs of the left and right stab.
I then marked out the requred cuts and bend lines to ready for its fabrication.
I bent the hockey stick pice in a similar fashion to the drive horns, in a vice with a half inch radius as per plans. it worked out well to the 18.2 degrees. Very happy with that as I did not want to have to re-order it after stuffing it up shall we say. It is about 8mm thick piece of aluminium with about 30 holes in it to attach to the front stab bar. I also drilled out the pilot holes to size 30."
