today I dimpled the window strap and the upper firewall. I also prepared the window strap for priming, painted the piece and then rivetted the strap to the upper firewall piece. I also rivetted the stainless steel filler box so the upper firewall assembly is now completed.
I prepared the shed for the joining of the assembled front fuselage pieces for connection. I inveted the rear fuselage, supported it on saw hoses and looped a strap from the shed roof to be able to roll the fuelage around its longitudinal axis single handed and also as a support in case it is knocked or bumped.
