"Today was spent mainly on getting the workshop in order for the wing assembly. I made 2 saw horses for the spar and wing to sit on out of the sonex international shipping crate pine 2 x 3's. crude but effective. I also cut about 6 inches of the length of my worktable to narrow it down to make more room in the shed. I also tidied up things in general and gave the shed a vacuum, as you do.
I also had to make a work top for my son Matty for a little table he has. It has been on the to do list ofr a while. As I was doing more woodwork today than metal work I thought I would knock it out and it also gets the table out of the shed nad into his room. He can use it for writing or other work he likes doing.
So 4 hours making wood items and 1 making a couple of aluminium brackets.
As for the root rib bracket I used the require.032 angle stock and cut out as per the plans the bracket for the rear rib. I need to do the forward brackets for the forward ribs. Had many interruptions so did not get a lot done."
