Hong Kong Waiex
Date:  11-1-2011
Number of Hours:  4.50
Manual Reference:  WIX-W14
Brief Description:  Wing Attach block remade
"I completed the new wing attach block from some excess block I had. I redrilled the 2 bolt holes and then bolted in place on te spar. This was my second block as the first , the holes did not quite align up correctly. the 2nd one was primed and then I placed both spars on the ground locked and clamped in place to drill the 1/4 inch hole through the block using the other spar pilot holes as a guide. worked a treat.
I also spent the day scotchbriting the parts for the wings. Namely ribs and gussetts and spacers. I managed to get them primed and I should be able to start assembling them tomorrow maybe!"
