"I located all the anghled parts required for the rear spar. Also pieced the c channel and alumium blank ribbon pieces required.
Started by measuring the right spar and marking for the cuts and holes and rivet locations. Manufactured the spar tip angles. Fabrciated the root angle blank pieces that fit in the root angle bolt positions.
Manufactured the spar splice plates that join the tip spar to the main rear spar."
