Brief Description: Left Main Spar - Rivetting Left Spar
"Today with Simon Sweetmans help I continued with rivetting the Spar root angles and all the dud rivets that I had done previously. It involved drilling off heads, punching through stem to drop them out and then re-rivetting with a new rivet. I replaced quite a few as I was not happy with them but by the end of the day the spar is basically complete.
I now have to drill through the root and wing attach blocks and the 3 alignment holes but will do this when not tired and also with some help to manouvre the spars around together whcih total 6.7m wide when joined. Will be doing that outside on the back tiled area, should just fit.
