I have sorted all the required pieces for the left spar which was easy as Ihad already located them and sorted them from the Right spar prep. I have fashioned the 2 wing attach blocks for the wing root and the other one. this was easier this time with the right spar experience and done in a more logical way using the spar pre drilled holes as markers instead of going blind from the plans. A better result. I have marked the reference linse for the various vertical stiffeners, angel brackets and wing root rib. Time is beating me today so it is just ready for attacking tomorrow and should be able to continue with some drilling and clecoing to the required hole sizes.
