Hong Kong Waiex
Date:  9-13-2012
Number of Hours:  4.00
Manual Reference:  WIX-F21
Brief Description:  Tail box, also deburr and prime remaining pieces
Today I continued with upsizing the drill holes to No.30 and also to 3/16 where bolts were required. I positioned the Rudder hinge as well and drilled the hinge in. All holes have noe been drilled to size and I was then able to deconstruct the box assembly and deburr the holes. this was relatively simple. I also removed the top left and right longerons to debur and prep for priming. I had to prime upper cross tie 3 that was not done, a cross tie clip for th cross tie box 1, the tail post strengthening strap and a couple of splice plates.
These have been primed and are ready for installation tomorrow.
Tail skid area
Tail skid area
Rrear bulkhead box and brackets
Aft tail web and angle pieces
