Today i prepared the splice plate pieces that joing the rear fuselage to the front fuselage. This required bending tothe specified angle using the vice and pole method. It was done easily. I also prepared the right rear fuselage panel measuring the holes to be cut and also the bend to jon the front fuselage. I did this with my make shift bending brake using the end of the table and clamped timber pieces. It was an effective way to do it.
I measured the longerons and cut and angled the ends as required by the plans.
