Hong Kong Waiex
Date:  2-17-2012
Number of Hours:  3.50
Manual Reference:  WIX-W14
Brief Description:  Right Spar preparation
I continued to deburr the main spar web and completed the final holes to size. I then completed the dimpling of the web and countersunk the required hole from the Sonex revision near the main spar block for a countersunk screw. I then scotchbrited and cleaned the web for priming which was completed with 2 coats.
I start the reassembling of the spar with the required screws and bolts to hold it together. I am awaiting for the rivets and rivet sqeezer to arrive before I can proceed with the rivetting process.
