Finished rudder cable closeout and worked on seat side closeouts. The seat side closeout mounting brackets are made a little too wide and once installed the closeout panel won't fit between the bracket and the seat rail. I had already riveted the bracket to the tabs provided for them that a welded to the structure so I bent them to allow more room to install the closeout panel. In retrospect I should have just drilled out the rivets and made new ones.
