Brief Description: Second front wing attach points entry
After getting the front of the Tee tube shortened and contoured I needed to shorten and contour the rear of the tee tube. To do this the reverse spot face tool was also used to shorten the rear of the Tee tube until the ring gage would almost fit but not quite. Then I filed the contour on the tee tube gradually shortening the tee until the ring gage would just slide into place.
