Brief Description: Clean up firewall forward punch list
Worked on the additonal air inlet cut out adding a plenum for ductwork. Clamp off the water hoses and add insulation/padding to protect them per the manual. I had to refit the oil cooler mount brackets as the cooler interferred with the bottom cowl.
