Paragraph 3-7 . Centered the windshield on the plane and match drilled the windshield at the spar carry thru tabs. figured out how to wrap the windshield, it is flat lexan to fit the conture of the top of the boot cowl and clamp to the door opening.
I clamped lexan to the door opening tube in just one place near the top then ran a ratchet strap over the windshield to the seat mount tubes in the fuselage. This nicely pulled the lexan into contact with boot cowl. Finally went back and added more clamps to the door posts.
Laid out hole pattern on the windshield clamping strip and began to drill them.
