Fitted the glovebox and drilled the mounting holes. Installed the last of the nutplates and found that there wasn't room for the #4 nutplates for the ELT remote indicator. I really don't want to use nuts on this as it will need to removed for battery service in the future. I decided to make a retainer for the back side that will drilled and tapped for #4 screws. This retainer will be held to the back of the main panel with a #6 screw. Started to make this retainer.
Also preped and primed the main panel and gauge insert.
