Paragraph 3. I had previously located the brake reservoir on the firewall per Figure 01H-03 per the text manual. I had not noticed that this location would not work with the provided premade hose to connect the reservoir to the brake bulkhead fitting. I looked at some S21 photos on Facebook since it uses the same firewall and the S21 online manual and moved the reservoir to the area indicated by this information. I am now stuck with extra holes in the firewall that will need to be blocked off.
The new location is on the opposite side of the aircraft. The location specified was just above the parking brake valve.
