Brief Description: Water rudder retract cable mount
I finished up making the mount for the water rudder retract cables. The plate is on the bottom of the boot cowl and provides the pass thru to get the retract cable into the cockpit and supports the rectract cable pulley supplied by Zenair in the float rigging kit. This will not installed for the final time until I move the aircraft from wheels to floats.
