To leak check the floats I used the pressure side of a shop vac and soapy water to check each compartment. I only found one leak and it was at the keel of one float where the rear "skid plate" is riveted on. Drilled out the leaking rivets, they were stainless steel and resealed with new rivets. All in all a messy job that was good to get finished.
