Brief Description: Started cutting templates for bulkheads
I started cutting templates out of wafferboard. After copying the paper templates onto the wafferboard and then cut them to shape with a router against a straightedge. Once the wafferboard templates are the perfect shape they will be used as a guide to router trim the actual composite bulkheads.
I eventually decided that this would result in too much transfer error.
