Brief Description: Nose Gear Rod fitting, Riveted Upper Nose GearPlat
The nose gear strut was binding a bit, so I adjusted the fit where it entered the fuselage.
I finished creating the upper nose gear bearing plate, primed it and riveted it on to the upper nose gear bearing support. I primed it some more after the riveting.
I started painting the nose gear legs and nose gear leg cap.
