Falcon XP Build Site (Claude)
Date:  5-1-2010
Number of Hours:  1.00
Manual Reference:  Part 1: 4.1
Brief Description:  Checking the Pod. Labelling locations.
Unwrapped most of the fuselage pod. The instructions say:
"Look over the pod to insure there are no major flaws, cracks or bad
blemishes. Using the drilling schematic for a guide, locate all the dimples
in the pod surface. Since these dimples will be drilled to attach brackets
and other parts, label each one with a pencil as you identify them."
Picture #2 shows an example of a dimple just a little below the white label that I used to mark the location of the "Fwd Throttle".
I went through and labeld lots of places on both the interior and exterior of the pod.
Fuselage Pod Revealed
Dimple Example
Dimple Example
Pod Trough
Pod Trough
