Brief Description: sanded rudder for clearance, re-set clearance of r
mounted rudder to vert stab to check clearancessanded inside edges of vert stab to increase clearance to proper sizeremoved section of vert stab ahead of rudder horn to provide adequate clearance to rudder hornre-installed honeycomb w/ flox ensuring that vertical surface is square and properclosed out w/ 1 BID laminate
