Brief Description: installed LH elevator access panel, bonded LH wing
installed LH elevator access paneldrilled mounting holesdrilled & countersunk nutplate rivet holesriveted nutplatesworked w/ Troy to remount rudder check operation & fit & removecut off sections of vert stab on side of lower fuselage which are not necessaryworked w/ Troy to bond the upper and lower trailing edges of the LH wing de-ice cuff w/ Hysol
