Brief Description: laminated all areas around horizontal stab to fuse
cut cloth, mixed resin & laminated 2 BID around all areas under horizontal stabinstalled conduit & wires into RH side of vertical stab for lights, antenna & trim tablaminated and bonded conduit into place including foam block to hold conduitmarked LH side of vertical where ribs will meetprep sanded LH & RH vertical for eventual bonding
