Brief Description: tail inspection panel laminates, laminates over RH
laminated 2 BID on inside of RH vertical stab for inspection plate flangefilled seam between RH vert stabn and fuselage w/ Hysollaminated 2 BID on inside of vert stab and stern postlaminated 2 BID to outside of vert stabcut out flange for inspection plate and drilled holes for mountingdrilled holes for rudder p/p tubes through aft bulkheadmeasured and marked tubes for rudder p/p tube fabrication
