Brief Description: Pressure bulked with fast build up/lowe mounts
Fast build (FB) pressure bulk head were put in palce, trimmed, refitted x 6. Finally fit was acceptable with foam and micro taking up the gap on the upper bulkhead back side. The FB pressure bulk heads don't fit great so ? iis it worth the cost. Upper lower bulk heads hysoled into place. Seat bottom. upper/lower panels cut and fit to bulk heads. Then drilled and cleco's. Upper and lower panels had fit and release done micr/flox mix. Presurrization regulator fitted to bucket in floor of backseat.
