Brief Description: finish & fill on rudder, laminates on RH wing to c
continued work on rudder by finish filing & sanding RH sidestarted filling LH side of rudder w/ micro--applied 2 coats of fill and sanded after each coatspot filled and sanded LH side of rudderworking w/ Troy laminated 1 BID over fill on RH wing top surface
