Brief Description: finished rudder trim tab, started rudder position
sanded gaps betwen rudder & trim tabe to 1/16"floxed small hole & pags from previous dayfixed both to & bottom closeouts fo trim tab that were sanded too thin when setting gapswidended actuator arm tab hole so that cotter pin washe will fitcut opening to rudder position light to shapecut out pre-cured laminate for mounting platedrilled holes for mounting screws & center hole for light
