Brief Description: set up & completed RH wing de-icing cuff TE bondin
setup for RH wing de-icing cuff trailing edge bondingworking w/ Troy mixed Hysol and bonded trailing edges of top & bottom RH wingclamped in placecompleted vertical stab tip close out using 2 ply pre-cured laminatefloxed in place and laminated 1 BID over surfacelaminated 2 BID to LH vert fin fuselage juncture
