Brief Description: started installation of pitch & yaw servos for a/p
installed yaw damper servo and discovered that core needed removal from bottom to create clearancecut inner skin, removed core, filled edge w/micro and laminated 4BID carbon over recesscut and filed phenolic mounting point for rudder bellcrank to fit yaw damperbegan fitting mounting bracke for pitch servocut phenolic for hardpoints, marked for electronics on auto-trim boxes
