My Lancair -N992BC IVP Garrett
Date:  6-30-2006
Number of Hours:  22.00
Brief Description:  laminated all areas around horizontal stab to fuse
cut cloth, mixed resin & laminated 2 BID around all areas under horizontal stabinstalled conduit & wires into RH side of vertical stab for lights, antenna & trim tablaminated and bonded conduit into place including foam block to hold conduitmarked LH side of vertical where ribs will meetprep sanded LH & RH vertical for eventual bonding
