Arrived lunch 3/9/06. Started where I left off on the gear doors. Measured and cut nylon snubber block for each door. Dillard micor'd and sanded the elevator x 4 with good results. Holes cut on posteroir belly behind luggage aea bulkhead. Areas prepped and wire mesh floxed. Cleaned up and reprepped for lay-ups inside floor. Aluminum brackets fab'd for condensore to stand up and ducting fashioned. Flap/aileron gap set and aileron travel adjusted by taking the aileron on and off MANY, MANY times.
BRRRR its cold
I hope this works
Please let me take the aileron on and off one more time!!!
