Measured and drilled the top-cover oil dipstick retaining plate hole. Tested the fit and then cut and sanded to shape the oil dipstick retaining plate ends. Installed the plate onto the top-cover. Measured, drilled, deburred (2x ea. per baffle plate) mounting holes and test fit the left & right cylinder head baffle plates.
