Sonex #237 Build Web Site
Sonex
Wire Looms
Measured, cut, drilled the sparkplug wire loom supports. Once satisfied I installed the wire looms. It helps make the engine look clean and neat! I discovered that the loom bracket washer/spacer are too small for the top cover SS pan head bolts.
Sonex Home
127
1 - Flaps Sport Acro
2 - Rudder
3 - Ailerons - Sport
3 - Vertical Stab
6 - Ailerons - Sport
76
