Brief Description: Top Cover & 5th Bearing Painting
Today I arrived at Mark P's Falcon Machine. While Mark started machining the case halves for the 94mm jugs I painted the Weseman 5th bearing front cover and the engine top cover. I then painted the case halves and Mark moved on to machining the heads. During some painting down time I put the push rods, rocker arms and guide plates in the tumbler for final cleaning. Grace sent up a Reverse Oil Filter Housing for us. I left Mark's shop at 2230 for OSHKOSH and the Sonex Workshop.
