Spoke w/ WW who recommended to go the 3100 Big Boy route. He also stated that I can use the bead blasted case. For the 3100 conversion I have to send Mark P from Falcon my Case and Heads and he can confirm my case is good to go. I dont need to test after installation of the oil pump kit as the buypass (the previously tested component of the rebuild) has been relocated to the Gold Oil Hub.
