While fitting the hydraulic pressure switch to activate the inner gear doors I noticed that the main gear doors are not fitting properly when the gear is retracted. I worked on creating a notch to see if it would help like another lancair in photo #1. Unfortunately I had to carve out much more. I have decided to create new gear doors like these: http://www.n91cz.com/Outback-Gear/Outback-source.pdf
