Keep on Keeping On! I've finished 38 ribs and only have 20 to go......I've used up all of my 3M Scotch-brite wheels, so I had to order more from Avery tools. I can still use the large 6" wheel in the bench grinder, but that does not work as well as a 2" wheel in the drill press. I've been thinking alot lately on how I'm going to do my Panel & Avionics. Still debating....but I did manage to find a very cool composite panel base to use. I don't know if I will use this or not, but I like the finished look to it. It looks more 'certified' than 'experimental'. I think I will end up with an EFIS system. I want the panel to look good, but somewhat simple. More later.
This is the panel I'm thinking of using .....I like the curves!
This is the panel mounted in an RV-6.....pretty impressinve!
