I got home from the site and discovered the DRDT-2 dimpler had been delivered. I assembled it and then thought of a way to set it up in the shop. I have seen on other builders' web sites how they set up their dimplers so the working ends are flush with the table top. I decided to rest the dimpler on 2 leg extentions from the end of one of the benches. The other bench can be pushed up end to end for a long flush working surface. You can also set a table in front of the main bench. This system should work out well. Tomorrow I plan on putting in a full day (Saturday). The first thing that needs to be done is shop clean-up. I will then countersink the spars and use the dimpler on the skins.
DRDT-2 after assembly
DRDTD-2 Dimpler in place - note the support legs and how the top is flush with the bench
