Brief Description: Foward seat covers, control rod tunnel and seat ba
Today is Christmas Eve.....Wendy went out to do her shopping, so I decided it would be a good morning to work on the plane. I started by fabricating the F-741A and F-741B tunnel support covers. This flange support is made from a z-shaped alum. piece. The cover is bent and drilled and will be drilled to the support angles soon. I next began to fabricate the pieces of the seat backs. I just about completed the left seat and put it in the fuse before I decided to quit for the day. I will work on the right seat back next time. I also got an order in the mail today. These are the button screws that I will use on the floors and the baggage bulkhead. The heads have a lower profile and they are stainess steel, so they should look better and hold up better than the brass screws supplied by Van's.
