I continued to do all of the little things that need to be done before I can rivet the fuse back together. I pulled off all of the seat and baggage floor skins and then installed the platenuts for the side seat ribs. These also need to be reamed out with a tap to allow easy insertion of the the screws when the seat pans are installed. The proximity to the edges make this difficult if the platenut is not reamed out. I also had to remove the platenuts along the center of the baggage ribs. I installed these before and they are not to be installed until the baggage floor skins are on. They were easily removed.
I installed the platenuts on the side seat skins. These need to be reamed out with a tap.
