No Longer Maintained
Date:  3-4-2008
Number of Hours:  4.00
Brief Description:  Aileron Bell Crank
Welded arms to bearing body. Cleaned bearing body so bearings would seat (post welding... took forever). Drilled hole for 5/16" tube, cut 5/16" tube. Rough cut slit in arms for 0.125" steel.
When bell crank is mounted on aileron support the 5/16 tube is exactly where it should be when in neutral position.
