Attached rib stiffener angles to right side center ribs with -3 rivets. Left and right #1 double center ribs stiffener angles did not match up well enough (don't know what happened???) so ribs and stiffener angles were match drilled to take -4 rivets. Too bad I don't have any #4 rivets. After rib stiffener angles are attached Bearhaw will be put on hold for a few months. Have a grand piano that I have to restore (hopefully will see for enough to buy an engine and prop). Also forgot to mark the attach point for the false spar on center ribs 2 and 5. Drilled AND started (started on one, did on the other) to rivet stiffener angle there had to drill out rivets. Left side center rib stiffener angles complete except for doubled #1.
