Finish welded second inboard aileron hinge mount. Less shrinkage on this one but still off enough that I want to correct. Tac welded 0.062 4130 to feet to correct shrinkage. Will shape and finish this afternoon or in the morning.
Update: Shaped 0.062 washers. Weld in morning.
The outboard aileron hinge mounts will be better corrected for shrinkage by making a small change in the way the 5/8" tube holds the bearing tube.
