No Longer Maintained
Bearhawk
Drawing 13
0.080 Flap Hinge Mounts
Drilled channels 3/16", 1/4" and 3/4" holes and cut rectangle for push rod. Shaped 3/4" hole for bearing tube to lay at the proper angle. Both mounts are ready for welding.
Bearhawk Home
464
Alodine
Forms
Jig Building
Layout
Primer
Rib Stiffener Angles
Wing Steel
68
176
224
