No Longer Maintained
Bearhawk
Aileron Support Frame, Inboard Flap Arm
Finished welding on the #2 end of the second aileron support frame and cut pulley support to correct length.
Had previously bent the inboard flap lever. Cut lever to correct shape. Cut, shaped and welded doubler to tip and welded arm to 7/8" tube.
Completed Frames
Flap Parts
Flap parts in order
Bearhawk Home
464
Alodine
Forms
Jig Building
Layout
Primer
Rib Stiffener Angles
Wing Steel
68
176
224
