Zenith CruZer & Sonex Logs
Sonex
08 - Motor Mnt/Gear
10-21-2009
SNX-P31
Drill Motor Mount
With all the shims set just right and final measurements confirmed, I drilled the lower two lugs of the motor mount to the fuselage attach angles. Looks like I will have decent, but not great, access to those dreaded lower attachment screw threads.
750 Cruzer Home
Sonex Home
2664
00 - Kit Arrival
00 - Miscellaneous
01 - Empennage
77
219
02 - Wing Spars
03 - Wings
119
389
04 - Flaps & Aileron
05 - Aft Fuselage
53
106
06 - Turtledeck
07 - Fwd Fuselage
114
224
08 - Motor Mnt/Gear
09 - Glare Shield
10 - Panel
43
84
11 - Windscreen
12 - Canopy
25
13 - Engine
83
148
14 - Cowling
219
Systems
389
