Zenith CruZer & Sonex Logs
Date:  8-13-2010
Number of Hours:  1.50
Manual Reference:  n/a
Brief Description:  Make Door Template / Locate vent frame
"Tonight I cut the opening in the door template I sized last night. I drilled a series of holes around the perimeter, cut it out with a cutoff disk in the dremel, then filed to size. It fits the door perfectly.
Next, I measured the offset for the vent doors on the inside of the fuselage, positioned the frame doubler, and drilled one corner hole. I then moved the doubler to the outside of the fuselage, cleco'd that one hole, and used a carpenter square to align it with the upper fuselage rail (looks a bit off due to parrallax error).
I then drilled the remaining holes thru the frame and fuselage. I will then remove this doubler, install my door template, mark and cut the opening, then rivet it all together."
Door Template
Door Template
Van's door frame (will be on inside of fuse when installed)
