Zenith CruZer & Sonex Logs
Date:  12-12-2009
Number of Hours:  2.80
Manual Reference:  SNX-C01
Brief Description:  Rudder Pedals
Removed the glareshield and panel to enable me to finish the under-tank stuff.
Cut stock to length and width for the left and right rudder cable adjustment link. These will be final-fit once the tail is on the plane and the cables are in place. Drilled a 1/4" and 3/16" hole in each (1/4 for the pivot, 3/16 for the return spring).
Drilled one mounting hole in each pedal block pair. Trial fitted with the pedals, then used that to locate the remaining hole. Drilled remaining holes, lubed up the holes with grease, and installed pedals.
Lastly, two return springs come with the kit. The builder must fashion the ends as shown in pic 3 below. I may try to make it have a bit more tension by shortening it a bit.
Overall shot of installed pedals
Close-up of the rudder cable adjustment link
Stock spring above, modified below
