Zenith CruZer & Sonex Logs
Date:  11-7-2009
Number of Hours:  2.50
Manual Reference:  SNX-C06
Brief Description:  Seat Pan Markup / Rough Cuts
Started on the seat pan so that when I flip the fuselage back over right side up I can get right to it.
Took a 3' x 4' sheet of .025 sheet stock. First cut it down to 40.84 by 32.5". Drew the lines on the stock, made a rough cut with the bandsaw, then used the Andy Snip to get it right on the line. Sanded the edges smooth; had a few splinters on the edge.
Then, marked the centerline for symmetrical measurements, and the bend line. Had to wipe it clean and re-measure as I was off just a bit.
From the centerline, measured the distances for the dual control stick cutouts. These will be in the shape of a triangle. You can kind of see the red markups on pic 1 below. Centerpunched the holes. I have a 4.5" and 3" hole saw set that will be used to cut the holes. Probably tomorrow.
Also marked-out and made rough cuts for the seat belt attach access, as seen in the middle of the pic below. Have to polish up the cuts tomorrow.
Seat pan looking aft
